Will the 4-Axis Xylotex board work with Jedicut using the MM2001 quartz-based timer board wired to the pin10 of the DB25?
MM2001 quartz-based timer board info:
http://gm.cnc.free.fr/CNC/timer_quartz.zip
Regards...Rick Diaz
Re: Jedicut and Xylotex
2Hi !
If you board parallel port is plugged like a MM2001 parallel port, yes your board will work. If not, contact me and we will work in order to do it possible.
3Hi everyone,
I try to download the program,but it doesn't run a setup on my computer! Can anybody help?
4Hi,
Jedicut don't need setup. Download the archive file, and extract files in a folder named Jedicut, and execute Jedicut.exe .
That's all folks
That's all folks
