I have now finished the mechanics of my foam cutter so I want to start trying to cut some foam. If I understand correctly there is no way to make the cutter go to a "home" position like 0,0 on each axis? I found the set reference option but I suppose that I need to move the axes manually and then save that position? It would be nice to have some arrow buttons to just move each axis without having to set a distance.
I intend to use limit switches on each axis and I see in the breakout board pin connections that I have 5 pins to use for this, but you have only one pin in Jedicut for Engine ON/Off. I could find a way with a rotary switch to use one switch but it would be nice to have individual pins in Jedicut. Just a suggestion......I think that Jedicut is an amazing program and thank you so much for all of your work in doing this.
Keith R
