Hola :
Recien ayer descubri esta pagina, y me parece fantástica.
Primera pregunta : como hacer , despues de abrir un archivo dxf para generar el corte o al menos, visualizarlo ???
La opcion no me aparece disponible.
Muchas gracias.
Jorge A.
Re: Dxf´s...
2Hola,
Disculpe, pero no hablo español desde tres años :/
Cuando quiere abrir un archivo dxf, la importacion cree un profile. graba el profile con jdp extension para utilizar le en una corte como todos los profiles.
Una otra solucion es de abrir el dxf como todos los profiles en una corte.
Re: Dxf´s...
3Hi Jerome:
Let´s switch language... By the way, your spanish is much , much better than my french!
(Je ne le parle pa, or something like that.)
Thanks for your answer. But seems I have a problem. I´m using Acad 2005, after saving a 25 mm per side "test pentagon" figure in R12, 2000 and 2004 dfx´s formats
i tryed to import the figure . This were the results:
a. Figure saved as R12 format, got a " impossible to open ficher " message.
b. With the 2000 and 2004 , part of the figure shows up , some coordinates on the up and down tables on the right side of the screen , but just 2 or 21/2 sides as a big drawing, nomatter if I save it as a smaller drawing first.
And in these last 2 formats, there are lines interconecting different parts of the drawing that not form part of the shape itself. Don´t know if I´m clear enough, hope you understand what i´m trying to say.
Is the import limited to some Acad version?
Do you have some written instruction ( english will be ok,
) on how to manage dxf ?
OR, WHAT am i doing wrong ????
Regards, Jorge A
Argentina
Thanks and
Regards, Jorge A
Argentina
Thanks and
Re: Dxf´s...
4Hi,
I understand your problem. Jedicut support that followings dxf R12 types of element :
- LINE
- LWPOLYLINE
- POLYLINE
- ARC
- CIRCLE
Can you send me your dxf R12 file by e-mail ? I will work on it in the next Jedicut version.
- LINE
- LWPOLYLINE
- POLYLINE
- ARC
- CIRCLE
Re: Dxf´s...
5Bonjour Jerome:
OK, i´ll send you the files used for testing.
You will see that the only line R12 fuselage test is OK, but adding just one arc produces 2 additional lines...( ??? ).
In a few minutes will be send.
Merci. ( My french is improving ! )
Jorge A.
Re: Dxf´s...
6Jerome:
Unable to send the files to this address taken from the forium ...
nnx[@-nospam]aeropassion.net
Where can I send you them???
Jorge A
Jorge A
Re: Dxf´s...
8Hi Jerome:
Did you received the files ???
Any comment about them?
Thanks
Jorge A
Argentina
Thanks
Jorge A
Argentina
Re: Dxf´s...
9Hi !
Yes I receive your files thanks. I'm sorry I don't find the time to look at it.I have an important todo list, notonly on Jedicut. But I'll work on it soon.
Re: Dxf´s...
10jorge,
I sent a response to this thread but it seems have disappeared...
since V2000, it seems Autocad generates "strange" R12-14-2000 DXF files, with some special lines making them non-compatible with many softwares.
to translates them in compatible version, try the a9converter freeware, here:
http://www.a9tech.com/download/A9ConverterSetup.exe
it makes clean R12 dxf files from stranges dxf.
